longest of long shots
Posted: Sat Aug 09, 2014 9:38 pm
by Jazzy
Gear selector shaft O ring leaking.
Any way of changing it with out taking the gearbox out.
Or any quality bodges.
Re: longest of long shots
Posted: Sat Aug 09, 2014 9:49 pm
by bolzenanker
Used 2 O rings for the time being and seemed to work but is a bodge. Need to change selector and sleeve/bush next time I'm in there.
Posted: Sun Aug 10, 2014 6:25 pm
by Jazzy
Ok stripped out the gearbox, rear hub off etc., etc.
pulled the spline out and lo and behold... Two O rings.
cant put my hand on sticky's book at the moment but Ive read on MBs that he has in the past used 3mm O rings.
Whats the proper fix?
Posted: Sun Aug 10, 2014 6:33 pm
by HxPaul
Jazzy wrote:Ok stripped out the gearbox, rear hub off etc., etc.
You can use the thicker 3mm o-ring,but if the bush or selector shaft are badly worn they should be replaced.
Posted: Sun Aug 10, 2014 7:41 pm
by Jazzy
thanks,
Does the sleeve knock out with a drift? if I took one from another case, would it be re-usable?
found stickys book but cant find it shown
Posted: Sun Aug 10, 2014 8:34 pm
by HxPaul
Jazzy wrote:thanks,
The bush has to be knocked out using a drift after the case is heated in that area.Using one thats been knocked out of another case is a bad idea because it wont necessarily be exactly the same size.Its always best to fit a new one.When you fit the bush it will need reaming to the right size.
Posted: Sun Aug 10, 2014 10:08 pm
by Jazzy
Thanks again,
Any literature available.
Posted: Mon Aug 11, 2014 8:57 am
by HxPaul
"Sticky's" red workshop manual,pages 50 and 70.
Posted: Tue Aug 12, 2014 10:09 pm
by Jazzy
Jobs a good un.
Old Bush knocked out cold , New needed some heat.
Double shim on top of the wishbone keeping everything snug.
Thanks to scooterresterations for quick dispatch.
