loom
Posted: Thu Aug 07, 2014 11:48 pm
by lou
Hi all ... question is... now tiding up a series 2 to ride as it is bit of a rusteration!! ... srtipping most of it down to clean and anchor wax ,, Do i need to change wire loom
as i will changed it to 12 volt ..or can i use exsisting loom , read somewhere to join all wires from the box together
or easyer to just change it
cheers
Re: loom
Posted: Fri Aug 08, 2014 8:45 am
by PeteB
May be as well to fit one of the "simplified" looms while it's in bits to avoid faffing around with connecting wires together, but also to have the safeguard of new wiring. Got mine from Scootopia: just ask tell them the loom is for a Series 2 and they'll supply one that's just that little bit longer.
Re: loom
Posted: Fri Aug 08, 2014 10:50 am
by Andy Pickering
What Pete said, for what a simplified loom costs it's a no brainer, I've got the MB one fitted brilliant and simple
Re: loom
Posted: Fri Aug 08, 2014 11:02 am
by Muttley McLadd
Having bought several different wiring looms for a Lambretta, I can recommend making your own.
