Hi all ... question is... now tiding up a series 2 to ride as it is bit of a rusteration!! ... srtipping most of it down to clean and anchor wax ,, Do i need to change wire loom
as i will changed it to 12 volt ..or can i use exsisting loom , read somewhere to join all wires from the box together or easyer to just change it
May be as well to fit one of the "simplified" looms while it's in bits to avoid faffing around with connecting wires together, but also to have the safeguard of new wiring. Got mine from Scootopia: just ask tell them the loom is for a Series 2 and they'll supply one that's just that little bit longer.
