koso speedo pick up mounted in a speedo worm housing
Posted: Sun May 31, 2009 11:50 am
by cezeta
im fitting a koso digital speedo pick up in a speedo worm housing on a scoot rs disc brake. it will be 45 degrees from the magnet. will this be ok?
Re: koso speedo pick up mounted in a speedo worm housing
Posted: Mon Jun 01, 2009 5:41 pm
by Fruitjuice
Magnetism doesn't mind angles, it's the distance between the pick up and magnet that matters, so should work perfectly....
Posted: Mon Jun 01, 2009 10:37 pm
by cezeta
cheers, whats inside a murcury switch?
Posted: Mon Jun 01, 2009 10:49 pm
by paulmgreen
mercury? :?
Posted: Mon Jun 01, 2009 10:57 pm
by sean brady scooters
its a liquid metal...........that conducts leccy..............and so can be used to make or break a circuit..........dependant on movement.................. :D
Posted: Tue Jun 02, 2009 2:09 am
by RICSPEED
sean brady scooters wrote:its a liquid metal...........that conducts leccy..............and so can be used to make or break a circuit..........dependant on movement.................. :D
arnt they used in alarms?
Posted: Tue Jun 02, 2009 2:13 pm
by paul-ebsc
and bombs :shock:
Posted: Tue Jun 02, 2009 3:48 pm
by fishi
why not using parts directly from KOSO ??
Posted: Tue Jun 02, 2009 10:07 pm
by cezeta
they are from koso, im trying to fit the koso pick up in the worm drive hole and mount the magnet in the threaded whatsit thingy that the worm drive is driven by.
because of the angle differance i just wanted to understand the workings incase of issues
