Dellorto 25mm BHBL jetting
Posted: Mon Aug 04, 2014 8:37 am
by Tractorman
I am fitting a 25mm dellorto phbl to a 150 barrel bored out to 175 and wondered if anyone has any jetting advise, please? It will be through a standard airbox.
Re: Dellorto 25mm BHBL jetting
Posted: Mon Aug 04, 2014 10:08 am
by Andy W
I have used a 25mm on a 175 kit with the following settings, but was running open mouthed.
MJ - 98, pilot - 51, atomiser - AQ266, slide - 40, Needle - D22 2nd clip. this was set up on the dyno and runs really well.
The owner has just fitted a foam filter on the bellows and had it checked at the weekend, I'm just waiting to hear what had to be changed.
Andy
Posted: Mon Aug 04, 2014 11:58 am
by Tractorman
Thanks Andy, bit more to them than SH carbs.
Posted: Mon Aug 04, 2014 1:09 pm
by flipster
Tractorman wrote:I am fitting a 25mm dellorto phbl to a 150 barrel bored out to 175 and wondered if anyone has any jetting advise, please? It will be through a standard airbox.
Have a look at my post http://scooterotica.org/forum/viewtopic.php?f=7&t=31698
You might recognise some of the contributors ! :D
Cheers.
