Page 1 of 5
Which ignition retard
Posted: Sun Jul 27, 2014 10:50 pm
by Rick
There seem to be a few on the market, I was looking to get an augsto 6000 but was wondering if one of the variable units maybe a better bet MTech or Kheper?
I'm running an Avanti TT3 with a supertourer and would like to get the bottom end back, Especialy the launch which is very poor. It was great with my old pipe.
Thanks
Re: Which ignition retard
Posted: Sun Jul 27, 2014 11:45 pm
by carlos fandango
Posted: Mon Jul 28, 2014 12:22 am
by monument7
Does this mean that each reply you receive is from a retard
Just asking
Posted: Mon Jul 28, 2014 1:58 pm
by Adam_Winstone
I went for the Agusto 6K for the same reason. NB: I had to file out my stator adjustment slots to get anywhere near a suitable starting point and retard finish.
Posted: Mon Jul 28, 2014 2:19 pm
by drunkmunkey6969
I find the MTech very useful, well priced, versatile and effective. I would recommend it.
Posted: Mon Jul 28, 2014 4:16 pm
by 1469leach
How do you go about setting up the mtech,do you find jetting the motor difficult with them? I've had a bit of trouble getting mine right,it seems difficult to get the mid range atomiser/needle combo to work well on my phbh.
Cheers Jeff
Posted: Mon Jul 28, 2014 4:24 pm
by drunkmunkey6969
I strobe it to the degree range I'm wanting to work within and then run it on my Dyno to dial the jets in.
Posted: Mon Jul 28, 2014 5:00 pm
by Donnie
yep mtech here too, great bit of kit, put it on the middle setting then jetted it to suit. also on a phbh and my needle / atomiser was a bit of a pig to get right too. went from a AV268 / x7 to AV266 / x13, that's on a 30phbh and clubman on a mugello 186
Posted: Mon Jul 28, 2014 6:41 pm
by Timbo
....best thing I did was to get rid of my Augusto...one less thing to go wrong.....
Posted: Mon Jul 28, 2014 6:51 pm
by stokky
Mtech for me.
Tell Martin what your set up is and he will give you a good starting point
I've got a couple, kitted bikes, can't be sure, but seem to remember being told to set at 19' and setting B (but could be wrong !)
