Cleaning flywheel and Stator plate
Posted: Fri Jul 25, 2014 11:31 am
by YAMLAM
ive been running without a flywheel dust cover and an open mouth carb (with panels and running boards) for a while now, there's lots of muck all over the flywheel and i suspect a fair bit on the stator, i`ll use jizer to clean the flywheel, but what should i use on the stator ? something that hopefully doesn`t leave a residue. what do you recommend ?
Re: Cleaning flywheel and Stator plate
Posted: Fri Jul 25, 2014 1:24 pm
by belly
For the electrics best stuff is Isopropyl Alcohol, spray on blow off with airline. Leaves no residue
Posted: Fri Jul 25, 2014 2:08 pm
by Tractorman
Loctite cleaner should do, may be the same stuff as belly recomended. Brake cleaner seems to leave a residue.
Posted: Fri Jul 25, 2014 6:28 pm
by coaster
I'm not sure I'd take a chance with brake cleaner on the coils, no telling what resistance the insulating lacquer will have to harsh solvents. I'd try WD 40 directly on the coils and when clean, wrap something round the coils for protection and use carb cleaner through a fine nozzle to wash off the backing plate.
Posted: Fri Jul 25, 2014 6:37 pm
by sean brady scooters
a tooth brush is also a handy tool in this case ,obviously not your own one tho lol
Posted: Fri Jul 25, 2014 7:59 pm
by psychedelicropcircle
WD40.
Posted: Fri Jul 25, 2014 8:14 pm
by speedy
sean brady scooters wrote:a tooth brush is also a handy tool in this case ,obviously not your own one tho lol
Nor the wifes either, as she will really see her arse. :oops:
Posted: Fri Jul 25, 2014 9:58 pm
by YAMLAM
cheers , wd40 , forgot about that.
Posted: Sat Jul 26, 2014 10:02 am
by hendy
coaster wrote:I'm not sure I'd take a chance with brake cleaner on the coils, no telling what resistance the insulating lacquer will have to harsh solvents. I'd try WD 40 directly on the coils and when clean, wrap something round the coils for protection and use carb cleaner through a fine nozzle to wash off the backing plate.
Do NOT use brake cleaner. It brakes down certain plastics and rubbers.
Whoever said use IPA was right; it's good stuff, but don't smoke when using it.
Carb cleaner is ok too, as it is deliberately formulated so that it doesn't damage seals etc on carbs. Wouldn't be much use otherwise would it?
