Cleaning flywheel and Stator plate
YAMLAM
ive been running without a flywheel dust cover and an open mouth carb (with panels and running boards) for a while now, there's lots of muck all over the flywheel and i suspect a fair bit on the stator, i`ll use jizer to clean the flywheel, but what should i use on the stator ? something that hopefully doesn`t leave a residue. what do you recommend ?
win or lose have a booze
belly
Main scooter: series 2 Li with TS1
For the electrics best stuff is Isopropyl Alcohol, spray on blow off with airline. Leaves no residue
Tractorman
Main scooter: Lambretta li150 special
Loctite cleaner should do, may be the same stuff as belly recomended. Brake cleaner seems to leave a residue.
I'm not sure I'd take a chance with brake cleaner on the coils, no telling what resistance the insulating lacquer will have to harsh solvents. I'd try WD 40 directly on the coils and when clean, wrap something round the coils for protection and use carb cleaner through a fine nozzle to wash off the backing plate.
a tooth brush is also a handy tool in this case ,obviously not your own one tho lol
psychedelicropcircle
WD40.
speedy
sean brady scooters wrote:a tooth brush is also a handy tool in this case ,obviously not your own one tho lol
Nor the wifes either, as she will really see her arse. :oops:
YAMLAM
cheers , wd40 , forgot about that.
hendy
coaster wrote:I'm not sure I'd take a chance with brake cleaner on the coils, no telling what resistance the insulating lacquer will have to harsh solvents. I'd try WD 40 directly on the coils and when clean, wrap something round the coils for protection and use carb cleaner through a fine nozzle to wash off the backing plate.
Do NOT use brake cleaner. It brakes down certain plastics and rubbers.
Whoever said use IPA was right; it's good stuff, but don't smoke when using it.
Carb cleaner is ok too, as it is deliberately formulated so that it doesn't damage seals etc on carbs. Wouldn't be much use otherwise would it?
    Users browsing this forum: Amazon [Bot] and 9 guests
