Page 1 of 2
Tick over issues
Posted: Thu Jul 24, 2014 10:08 am
by Snails
Hi
My Lui 125 is now back on the road (well it will by the weekend when it passes its MOT retest) but having driven it on the road properly it has a problem ticking over when I come to stop at lights etc. Ticking over in the garage (once warm) is fine but using on the road its either wanting to die or kind of over revving...I was wondering if this is a sign of having the incorrect pilot jet?
Its using jetted as per a Vega using a sh1/20 carb with a larger main jet to accommodate its 125 ccs
Re: Tick over issues
Posted: Thu Jul 24, 2014 5:41 pm
by wack 63
It's worth a try with larger idle jets, after all its a bigger cylinder .Also consider the float and needle, lean one minute, rich the next. Fuel flow thru tap, although I use a Vega tap on a 130. Plus might be best to pressure test the motor for air leaks.
Posted: Sat Jul 26, 2014 8:25 am
by Snails
Thanks. Will try jet first as easiest. God knows what my tap is but it ain't Vega. If it was too small you' d notice when moving along wouldn't you?
Lastly how do you pressure test an engine
Posted: Sat Jul 26, 2014 8:26 am
by Snails
What pilot float and needle do you have on your 130?
Posted: Sat Jul 26, 2014 9:55 am
by wack 63
Sorry running a PHBL 25 so no use to your set up. You can make an easy tester by using a piece of push bike inner tube with the valve connected to a foot pump. Jubilee clip it onto the inlet pipe and exhaust stub, pump up a few psi and listen for leaks and spray all around the gasket faces etc with soapy water.
Posted: Sat Jul 26, 2014 1:05 pm
by Adam_Winstone
I don't know what carb or choke mechanism you are running but this is typical of a choke being adjusted slightly too tight or the plunger not seating correctly. You can set tickover, however, once on the road it becomes hit and miss (stalls or over-revs) as it finds additional source of fuel to mess up the fuel/air balance.
As it could be a number of other factors too... good luck solving this one.
Posted: Sun Jul 27, 2014 5:40 pm
by LI225Canada
I was having similar issue setting up my PWK. Ended up being float height, not enough fuel in the bowl.
Did all the required modifications, checking the height was one thing I skipped when installing it.
Posted: Mon Jul 28, 2014 8:11 am
by Snails
wack 63 wrote:Sorry running a PHBL 25 so no use to your set up. You can make an easy tester by using a piece of push bike inner tube with the valve connected to a foot pump. Jubilee clip it onto the inlet pipe and exhaust stub, pump up a few psi and listen for leaks and spray all around the gasket faces etc with soapy water.
Thanks. I take it you test the inlet and exhaust desperately rather than at the same time?
Posted: Mon Jul 28, 2014 8:12 am
by Snails
LI225Canada wrote:I was having similar issue setting up my PWK. Ended up being float height, not enough fuel in the bowl.
Its a sh1/20 so shouldnt be an issue but thanks for the suggestion
Posted: Mon Jul 28, 2014 8:13 am
by Snails
Adam_Winstone wrote:I don't know what carb or choke mechanism you are running but this is typical of a choke being adjusted slightly too tight or the plunger not seating correctly. You can set tickover, however, once on the road it becomes hit and miss (stalls or over-revs) as it finds additional source of fuel to mess up the fuel/air balance.
Thanks Adam I will check that out
