Carb Jetting query
Posted: Sat May 30, 2009 8:27 am
I have recently moved form 200cc to a 225c top end, the pipe and the 30mm PWK have remained the same. I was under the impression that due to this increase in cc I would need to up jet the card to allow for this. In practice however it bogs down in the midrange when I increase the main form the original 122 up to any other size apart for a 125 when it start to run cleaner. When I did some research in the tuning guide section I found this piece of info:
"The piston diameter and carb bore diameter are closely related. The larger the ratio between the piston size and the carb size, the higher the intake velocity. That makes the jetting richer. Figure on leaning the jetting after an engine is over bored."
This would imply to me that I should have a probably left the 122 fitted as it run perfectly for 2000 miles or even fitted a smaller jet. This seems a strange concept and also goes against what I always believed, can any one of you tuning gurus conform that this is the case , or not.
