Page 1 of 2
T5 indicator probs
Posted: Thu Jul 17, 2014 10:10 pm
by carbon lammy
T5 classic rear indicators come on but don't flash,front ones flash as normal,new indicator switch and flasher unit fitted,wiring checked earths cleaned and checked if I swap wires on switch rears flash and fronts stay on,any ideas what's wrong
Re: T5 indicator probs
Posted: Thu Jul 17, 2014 10:18 pm
by firekdp
Is the headset tell-tale light working ok?
Posted: Fri Jul 18, 2014 1:23 am
by coaster
I think I read somewhere that the T5's indicators flashed alternately front/rear so that only one lamp was on at a time. That was supposed to limit the current drain and stop the headlights dimming? I did have a T5 but when the indicators developed a fault I changed the flasher unit and the new one definitely flashed front/rear at the same time and I hadn't noticed what the original one did before it failed :? The reason I mention it is if true, that might explain how front and rear could operate differently.
Posted: Fri Jul 18, 2014 5:36 am
by carbon lammy
No mate tell tail not working
Posted: Fri Jul 18, 2014 11:10 pm
by lambro
Check the buzzer wires in the tool box haven't connected and taken the red to earth.
Had that once.
Posted: Wed Aug 13, 2014 2:59 pm
by soulboy
relay behind spare wheel
Posted: Sun Aug 24, 2014 9:28 am
by carbon lammy
Demented now I've changed every indicator part on my scooter,checked continuity of every wire still not working rears flash as normal fronts just come on and don't flash anybody any ideas what's wrong,tell tale does not flash but bulb and wiring ok as is speedo wiring,help
Posted: Sun Aug 24, 2014 12:32 pm
by Norrie Bodge
Could be a regulator fault maybe??
Try 4 12v 10w bulbs see if that helps
Posted: Sun Aug 24, 2014 2:06 pm
by carbon lammy
I have mate it's not that
Posted: Tue Aug 26, 2014 7:47 am
by lambro
Do a continuity test on the red feed wire, buzzer end will do and see if it has gone to ground.
Exactly the same fault on a mates, and thats what it was.
Worth a look.
