bent layshaft
Posted: Tue Jul 15, 2014 8:08 pm
hi all have i got a bent layshaft,fitted new hub[good sil one] af rims run out 3mm
The UK's No1 Lambretta & Vespa Scooter Forum.
https://www.scooterotica.org/forum/
I'm inclined to agree, could even be that the rim isn't seating properly due to thick paint or powdercoat. Easy to pinpoint by jacking the rear wheel up so that it can be rotated then use a suitable block of wood to hold a pointer against the centre point of the wheel nut and then the rim/tyre/hub to check for run out.nastro azzurro wrote:Will be the hub or rims, not layshaft. 3mm??? how did you notice that???
