Dodgy clutch
Posted: Mon Jul 14, 2014 4:01 pm
Hi there
My clutch is playing up, and I wondered if anyone has any thoughts
I have got a standard 4 plate clutch in a TS1 225 motor, everything has been fine until I went for a ride the other week. I was changing down for a roundabout and the clutch lever didn't want to depress all the way...it felt as though something was obstructing. At the same time, the clutch wasn't depressing completely, and I stalled the bike.
I put this down to a stretched cable and managed to limp home. I changed the inner cable, and took the casing off to have a look...all looked ok so I put it back together.
I rode to work today and all felt fine for about 15 miles...then it felt the same again, as if the cable had stretched. I stopped and adjusted the cable to remove any slack, but it just doesn't feel right, the lever isn't depressing smoothly, and the clutch feels rough....could it be the springs, plates or both?
Any advice gratefully received
Thanks
Thanks
