Dim headlight at tick over.
Posted: Sun Jul 13, 2014 5:10 pm
Just about completed my rebuild and ran it for the first time in the dark to check out the head light. Found that the headlight is very dim at tick over. Once it is revved up a bit the light is good and bright. This is my first Lammy with 12v AC so I am not sure if this is normal.
My set up is;
Rapido 225 classic.
Asso piston.
58mm GP crank.
Ancillotti exhaust.
26mm PWK carb.
AF lightened flywheel w. Indian stator.
Ducati coil.
Swiss regulator
Battery runs all other lights except headlight. (This systems works fine)
Halogen headlight bulb.
Beedspeed loom (Serveta system w. battery and turn indicators)
The motor tick over is rather rough (think Harley) and the headlight intensity is in sync with the rough tick over. (If the motor misses a beat the headlight dims accordingly)
Question is, is the headlight dimming at idle to be expected with this setup?
Maybe a faulty stator can cause a rough tick over and dim light?
Thanks for any input.
My set up is;
Rapido 225 classic.
Asso piston.
58mm GP crank.
Ancillotti exhaust.
26mm PWK carb.
Ducati coil.
Swiss regulator
