Cush drive bids for freedom!
Posted: Sun Jul 13, 2014 3:08 pm
by lammer205
Hi all , i've just rebuilt a motor all shimmed up and torqued put it back in scoot and go to kick it over kickstart very stiff and not returning , i gave it a few kicks out of frustration to be honest, then sat down for a relax smoke and noticed a hairline crack at the cush drive this was on a polished casing so quite visible, so casing back of and some damage there alrite, so i need to know what happened here and what to do to sort out all help appreciated. thanks Lammer205
Re: Cush drive bids for freedom!
Posted: Sun Jul 13, 2014 3:59 pm
by Morgan
The cush drive was probably not seated correctly, causing it to sit proud and catch the casing. Seen it done before and cracked the casing when tightening up.
Posted: Sun Jul 13, 2014 6:34 pm
by lammer205
Yep i seen what i've done there
, thanks Morgan! Lammer205
Posted: Sun Jul 13, 2014 11:10 pm
by Pepot
Had a similar problem after having changed the kickstart shaft. It had like a "nipple" on its inner side that faced the clutch and didn't allow the casing cover to sit properly. Grinded that "nipple" with a dremmel and solved it. It would explain the stiffnes of your kicstart.
Posted: Mon Jul 14, 2014 9:08 am
by joeswoonara
opps seen it done , luckily not by myself ,
i always tw@7 the cush drive with a hammer to see if the spring bounces , you also get a solid "clunk" if it`s not seated properly , the casing can be welded on the inside and re-polished
