brenbo master cylinder
Posted: Sun Jul 13, 2014 12:39 pm
by satans reject
morning all,
these brenbo master cylinder seem to be the new next thing, (the green cutdown in this months scootering....) anyone one out there using one and which 'model'?
thanks
scott from morecambe
Re: brenbo master cylinder
Posted: Mon Jul 14, 2014 10:32 pm
by corrado
There's loads of different ones on the market of that style, the difficulty is in making it fit the Lambretta light switch housing. MB used to do a switch housing to mate up with these motorbike style fitment master cylinders.
They look odd to me unless you've got a hydraulic clutch and use a matching master cylinder for the clutch too.
Posted: Tue Jul 15, 2014 7:43 am
by soulster22
Got one fitted on my GP and it looks the nuts. like the way you can adjust the lever inwards or outwardly and the master cylinder itself is a work of art.
will try to post an image later if possible.
regards Harry
Posted: Tue Jul 15, 2014 8:09 am
by Agent Buchwald
There are a lot of fakes around for those that like to make life more interesting than it really is.
Posted: Tue Jul 15, 2014 10:19 am
by corrado
"Brenbo" sounds like a fake to me, unless it's a tribute brake. :lol:
BGM one might be suitable ...
http://www.scooter-center.com/product/B ... tmatch=ALL
Posted: Tue Jul 15, 2014 11:24 am
by shocky
Looks good on a R1 sadly not on a lambretta. looks like the sort of thing someone would fiddle with when the scoot wasleft unattended
Posted: Thu Jul 17, 2014 5:41 pm
by satans reject
soulster22 wrote:Got one fitted on my GP and it looks the nuts. like the way you can adjust the lever inwards or outwardly and the master cylinder itself is a work of art.
regards Harry
harry,
have you dug your camera out yet?
scott
Posted: Thu Jul 17, 2014 10:30 pm
by Jonny mars bar
Hi, it's my cutdown in scootering. Radial master cylinder is a brembo 16 x 18. It's probably the best bit of kit on the scooter. Loads of feel to the brake, much better than the Nissin type although Nissin radial ones are good they don't look as good as the brembo. I use an mb mount although you have to get it welded a little as the brembo mounting holes are off set slightly. I will try and post a picture up tomorrow.
You can get a radial master clinnder from ped parts, the same as the bgm ones..
Cheers jonny
Posted: Fri Jul 18, 2014 8:16 am
by soulster22
Jonny mars bar wrote:Hi, it's my cutdown in scootering. Radial master cylinder is a brembo 16 x 18. It's probably the best bit of kit on the scooter. Loads of feel to the brake, much better than the Nissin type although Nissin radial ones are good they don't look as good as the brembo. I use an mb mount although you have to get it welded a little as the brembo mounting holes are off set slightly. I will try and post a picture up tomorrow.
Cheers jonny
Good morning Gents, my master cylinder is the same as Jonny's and as requested i have attached a photo below. will send one of it fitted to the Lambretta later.
https://flic.kr/p/o5UJ3m
regards Harry
Posted: Fri Jul 18, 2014 8:40 am
by soulster22
regards Harry
harry,
scott
Morning Scott,
image of the brenbo brake assembly as fitted on my GP
https://flic.kr/p/nXiPJT
Regards Harry
