HELP! Lambretta Gearbox noise
The Hiwatts
Main scooter: SX
We have come to the conclusion after 14 gearbox/clutch rebuilds it's time to give in!!!
We are no further forward with it from the first rebuild!!!
I have put back in my original 150pacemaker engine and taken out the rebuilt 200, and will have to give it another go at a later day!!!! :cry:
Oh well!!!! Any ideas or suggestions apart from selling it off or burning would be welcome!!!!
Enough is enough :evil:
Thanks for the input and comments so far - top guys!!!
fritz
[quote="wack 63"]Sliding dogs catching gears when in neutral?
good shout by wack 63 did you change sliding dog?
same problem cost me tooth off first gear and cluster :oops:
see wanted section
HxPaul
dapper wrote:Also check that end plate studs/bolts aren't catching on the inside of the rear sprocket. Oh, and when you've sorted it post what was the eventual problem ;)
It could be the chain hitting the end plate studs or layshaft bearing race,if the crown wheel shim is to thin or non existant.
brianc
Main scooter: lambretta gp
hi everyone,i ve got exactly the same problem,toataly re-built new everything gp175 in a series 2 case,i didn't worry about it too much till now,i was thinking it was just the chain as mentioned earlier,but now I don't know,
brian.
bazza3004
bottom chain guide catching rear sprocket ?
brianc
just took the chaincase cover off mine,turns out the clutch top steel plate has been rubbing on something,think its the inside of the kickstart,
brian.
brianc
had another look at mine and its definitely the kickstart shaft wearing away the clutch top metal plate,looks like the kickshaft shaft is over cast,so I took off some metal with the angle grinder,
brian.
brianc
everything back together again,noise still their,goes away as soon as clutch pulled,
brian.
