t5 172
Posted: Tue Jul 08, 2014 11:23 am
by soulboy
is the head gaskit needed
Re: t5 172
Posted: Tue Jul 08, 2014 1:19 pm
by ducksta
no
Re: t5 172
Posted: Tue Jul 08, 2014 2:13 pm
by jackson85
Do you have the original head modified? My understanding from the Malossi instructions was you use the gasket withthe standard head. Modified ones are normally setup for no gasket
Re: t5 172
Posted: Tue Jul 08, 2014 7:29 pm
by goldeneye
get a proper head, itll be cheaper than the 3 pistons you"ll f@@k up before you realise you need the proper head.......
Re: t5 172
Posted: Wed Jul 09, 2014 1:07 am
by paul d
If you modify the head as it says in the malossi booklet you need to use the gasket. I dremmelled the combustion edge at a 45 degree angle as per malossi instructions, used the head gasket provided and ran it flat out for the life of the first kit (4 years) but the compression was very high. I add 1% oil to the tank along with the autolube too. Always fully synth....well nearly always!
Re: t5 172
Posted: Wed Jul 09, 2014 12:19 pm
by soulboy
I have got a proper head I think I got it off ducksta
Re: t5 172
Posted: Wed Jul 09, 2014 12:54 pm
by ducksta
which scoot soulboy if its off the hybrid its been machined correctly, but i havnt sold any t5 heads :!: there like rocking horse shite
Re: t5 172
Posted: Wed Jul 09, 2014 1:52 pm
by soulboy
I swapped it for my standard head he may not have been you pal do u use a head gaskit
Re: t5 172
Posted: Wed Jul 09, 2014 7:40 pm
by ducksta
my head has been machined so no gasket used
