Page 1 of 2
Legshield bracket fix
Posted: Sat Jul 05, 2014 6:39 pm
by Livi- Graeme
The bracket behind the horn cover has come away and I was wondering if anyone had any suggestions to fix it back on without welding. I thought of making some sort of stainless cover piece that could wrap round the legshield middle and then bolt or screw into the bracket behind the horn cover. As a last resort I will get it welded but really don't want to have to repaint the legsheilds. Any suggestions would be appreciated. Graeme
Re: Legshield bracket fix
Posted: Sat Jul 05, 2014 9:33 pm
by rosscla
Sorry just reread that and realised you meant the one that fixes the legshield to the frame not the horn bracket.
You might be able to solder or braze it back into place temporarily but I doubt it would last.
Posted: Sat Jul 05, 2014 9:49 pm
by Livi- Graeme
Just grasping at straws totally gutted. Must have happened when I came off coming back from Berwick bulldogs rally
Posted: Sat Jul 05, 2014 10:00 pm
by rosscla
Has the whole c shaped bit come off or is it broken?
Posted: Sat Jul 05, 2014 10:16 pm
by jason frost
Drill though and bolt it together. 4x m4 bolts will hold it and not look to bad, weld it next time you paint it.
Posted: Sat Jul 05, 2014 10:38 pm
by Livi- Graeme
Aye was thinking of making a bracket as camouflage similar to those old luggage holder brackets you can get
Posted: Sat Jul 05, 2014 10:40 pm
by Livi- Graeme
All the spot welds have broke off. Must have happened when I had a spill coming back from Berwick bulldogs rally
Posted: Sun Jul 06, 2014 1:34 am
by Trojan
Had the same thing happen to me when I was fitting my legshields back on after being painted..
brand new leggies and the bracket snapped off, not even been on the road yet, decided the best course of action was to drill straight through and fit a domed shaped bolt with a J shaped bracket so it looks like a helmet holder....does nt look Too bad even though I did nt really want one in the first place.......
Posted: Sun Jul 06, 2014 3:19 pm
by Livi- Graeme
this is how I sorted it. Hope it holds out
Posted: Sun Jul 06, 2014 11:36 pm
by rosscla
With the wheel on the you'll never see that
