Electrex ignition wiring
Posted: Fri Jul 04, 2014 6:24 am
by bogs
Ok I have just got a 12v electrex ignition.
It has 5 wires coming out of the stator. Red white and green as normal that go to the cdi . Then it has 2 yellow wires as opposed to the usual single yellow wire.
The regulator/ rectifier has 4 ports. Earth , charge, feed from stator in and feed to lights out. So what's the second yellow wire from the stator for?
Re: Electrex ignition wiring
Posted: Fri Jul 04, 2014 6:53 am
by Minority
Don't the "normal" stators converted for Wassel DC have two yellow wires?
Just a thought.
Posted: Fri Jul 04, 2014 7:04 am
by Pepot
If you use an AC regulator or a DC half wave rectifier, you must conect the second yelow wire to earth (frame).
Posted: Fri Jul 04, 2014 8:49 am
by bogs
Thanks Pepot. Does it matter which yellow wire goes to the frame?
Posted: Fri Jul 04, 2014 9:48 am
by Pepot
bogs wrote:Thanks Pepot. Does it matter which yellow wire goes to the frame?
No, it doesen't matter.
Posted: Fri Jul 04, 2014 10:41 am
by bogs
Thanks for your help Pepot ... Thumbs up
Posted: Fri Jul 04, 2014 2:02 pm
by Pepot
Thinking about it. If the regulator has a full wave rectifier, then both yelow wires must go to the regulator (like in a wassel ). Then the exit port of the regulator would go to the battery. Check what kind of regulator is yours.
Posted: Mon Jul 07, 2014 12:16 pm
by bogs
The regulator is a idm RR212 for ac lighting and dc battery charing made in Italy
It only has 4 ports but the stator has 5 wires,an extra yellow
Posted: Wed Jul 09, 2014 11:36 am
by Pepot
Since you are going to use a battery, wouldn't be better using a wassel regulator? You just would only have to replace your AC horn for a DC one and run the rest of things from the battery.
