Problems with fitting a replacement PX Mk1 Speedo cable
Posted: Wed Jun 25, 2014 9:42 am
by wink
Hi all, I've just fitted a new speedo cable to my PX mk one and I have replaced all the various components.
When fitted from top down (headset first down to hub), I can turn the cable manually at the bottom of the cable and the speedo works fine, but as soon as I fit the cable into the hub the speedo stops working. Conversely, when fitted from bottom up, the cable turns freely at the headset end, but as soon as I connect it to the actual speedo it doesn't work.
This is driving me around the bend so any help would be very much appreciated.
Thanks in advance
chris
Re: Problems with fitting a replacement PX Mk1 Speedo cable
Posted: Wed Jun 25, 2014 9:55 am
by timexit17
is the outer cable too long perhaps?
i.e. its not allowing both inner ends to be fully seated into the speedo/worm
Posted: Fri Jun 27, 2014 6:38 am
by wink
Hi timeexit,
Well I adjusted the outer cable and the speedo is still not working, I can actually hear/feel the inner moving in the outer cable so I can only assume that the actual speedo is buggered (it was old and untested).
Looks like I'll have to try and get hold of another working mk1 speedo, to test it against. If anyone has got one for sale or that I could borrow then please pm me
Thanks again for the help,
Chris
Posted: Fri Jun 27, 2014 6:52 am
by brucie
feeding it up from the bottom into the speedo and turning the cable by hand won't give enough revolutions to make the speedo work so you can see it.
When you fitted the cable from headset down did you fit it into speedo drive on front wheel. if so without the cable fitted into the speedo spin front wheel to make sure it is turning at the headset end to make sure it is in the drive correctly, if it isn't you will need to mess around with it until it does.
If it is turning ok after this the cable should have about 10mm where the cable fits into the speedo before the stopper. I have had them before where there is not enough to fit into the speedo and hence it does fit inside the speedo to make it work.
Hope this makes sense.
Cheers Bruce
