28mm delli on a sil 200
Posted: Thu May 28, 2009 12:21 pm
by shilloboxer
Hi any help would be appreciated setting up my lammy chop
28mm delli no filter on a sil 200 engine standard webster exhaust.
40 slide, x7 needle second clip, AV264, 118 main, air screw 2 turns
This has been the closest i have got it and it feels quite crisp bit concerned about the main (118). I have also tried to up the main to 125 then 122 but it bogs down at 3/4 throttle to full. I have also tried X2,X13 and AV266 but the above has been the best, but like i say just a bit worried it could run too lean.
Re: 28mm delli on a sil 200
Posted: Fri May 29, 2009 6:09 am
by lammydave
best bet is to keep a close eye on the plug colour.....
Posted: Fri May 29, 2009 11:16 am
by bootros
I use the same carb, engine and jets/needle as you with the only exception being a 120 main and a PM exhaust.
Seems to be a fairly standard set-up which is encouraging.
