Page 1 of 2
JL end can mounting
Posted: Tue Jun 24, 2014 7:52 pm
by goldeneye
well, my JL end can mount chucked its guts again, only done two rallies and a bit round the doors with this one...., its the rubber mounted bit onto the shocker bolt...any suggestions on a replacement that wont drop to bits? (third one on this pipe) 2nd time ive had to ride home with it wired up with cables......
Re: JL end can mounting
Posted: Tue Jun 24, 2014 8:40 pm
by Muttley McLadd
See if you can get hold of the guy from TSR. He was having some brackets made that you can fit a regular three bolt can onto. He was aiming at having them ready about now, IIRC.
Posted: Tue Jun 24, 2014 8:58 pm
by goldeneye
this for me vespa Matt, not lammy. was gonna make something up, but apparently its a common problem, so it would be a good point out for other peeps as well.
Posted: Tue Jun 24, 2014 9:14 pm
by Muttley McLadd
Yup, it's for RHS coop ones
Posted: Wed Jun 25, 2014 3:28 pm
by goldeneye
cheers Matt, I"ll give it a look.
Posted: Wed Jun 25, 2014 3:32 pm
by ducksta
look at the one on the revolver exhaust they quite chunky
Posted: Wed Jun 25, 2014 11:23 pm
by paul d
My brother uses classic austin mini bobbins. They seem to last longer than the rubber mount thing that comes with the pipe (look very similar though)and can be bought cheaply in any motor factor. Even Halfords have them in stock.
Posted: Mon Jun 30, 2014 11:35 pm
by goldeneye
gonna have a go using a modified vespa rear shock mount rubber, that should last a while.
Posted: Tue Jul 01, 2014 12:56 am
by Muttley McLadd
Are you out of big zip ties?
Posted: Tue Jul 01, 2014 5:48 am
by LI150
I solid mounted mine using a machined price of acrylic. Been on a year works great
