Digital Tachometers
CT.
Hi, not looking for anything fancy just a neat digital tacho that would have also the provision for CHT or EGT and can easily be transferred from scooter to scooter. To be mounted in/on a small bracket at the top of legshields or on top the toolbox.
Any ideas or links welcome.
Thanks.
dapper
http://www.sip-scootershop.com/Products ... e+III.aspx
http://www.sip-scootershop.com/Products ... tails.aspx
I know they're not digital, but they do have EGT as well, but worth a look at others on this site
CT.
Thanks dapper, I dont mind analogue either It's just those look a too modern. I know that sounds odd when looking at digital tacho's but if analogue it would have to far more classic looking with a sensible scale - maybe up to 9-10 thou rpm. Also like the Krober ones but they're expensive, you lose the EGT & will need re-charging if your not DC/Battery.
This one looks alright on their site. It says you need a battery and theres only water temp.
http://www.sip-scootershop.com/Products ... +2T4T.aspx
Edit: just looking at the LTH site, they show a 9v batery pack intended for Koso instruments so that'll be what's used then
http://www.lambretta-teile.de/product_i ... ments.html
Would be interested to see what other people are using too please..
Thanks.
DaveInPortland
Does the tach sense revs via a small wire wrapped around the spark plug wire or via plugging in to the CDI?
I use this: http://www.tinytach.com/tinytach/commercial.php
Dave
Lucky b@5t@rds SC, Portland, Oregon, USA
Lambretta Club USA
ArKaTxU
You have too this item, that looks better than a 9v battery for me:
http://www.lambretta-teile.de/product_i ... 5V-DC.html
scooty
Koso do this one which is about 50mm so would go in a hole in legshield toolbox easily
this was advertised at scooter center koln
http://scooter-center.com/catalog/popup ... roducts%2F
Bilko
Main scooter: LI150
scooty wrote:Koso do this one which is about 50mm so would go in a hole in legshield toolbox easily
Do these work ok with Varitronic ignitions?
Bilko's Oily Blog
scooty
Bilko wrote:Do these work ok with Varitronic ignitions?
Dont think they do m8 :roll:
Bilko
Main scooter: LI150
Balls! :( Thanks for the reply anyway.
Bilko's Oily Blog
CT.
Oh well, it seems it's not easy to find a small digital unit with EGT.
Had a look on the Koso site their Stage 6 one can have a CHT sensor fitted though.
    Users browsing this forum: No registered users and 22 guests
