Non Starting Runner From Cold?
Posted: Mon Jun 23, 2014 9:02 am
by Treeman
Hi my SP Runner won’t start from cold on the electric start, it’s OK if you kick it. Had the carb looked at and the shop says it’s OK, but the automatic choke doesn’t seem to come on? Any ideas would be happily received, thanks.
Treeman
Re: Non Starting Runner From Cold?
Posted: Wed Jun 25, 2014 5:47 pm
by shocky
My dragster didthat nevergottothe bottom of it
Posted: Wed Jun 25, 2014 6:25 pm
by rainbowrunner
Hi, Your battery needs to be in tip top condition , the more amps the better for starting ie 11 or 12 amp.
you can buy a manual choke unit from PSN Tuning
http://www.psntuning.co.uk/scooter_part ... rt_id=1848 alot better than the auto choke.
Had one on my runner 180 sp,
hope this helps
Posted: Thu Jun 26, 2014 3:13 am
by Treeman
Hi and thanks guy's. Just put a new battery on and still the same. Will try the manual choke.
Posted: Mon Jul 07, 2014 8:28 pm
by leftside
hi treeman, i had an italjet that wouldnt start off the button, could get it to start by kicking it (not first kick i may add) after changing starter , new battery, taking carb off, turns out the head was loose, not saying thats yer problem but its only 4 nuts innit
Posted: Mon Aug 18, 2014 12:27 am
by Treeman
Thanks leftside all those items are ok. Have now found the battery is charging at a low rate, what could cause this?
Posted: Mon Aug 18, 2014 11:49 am
by Treeman
The variator cog just rounded off, guess that may have had something to do with the starting recently!
Posted: Sat Mar 18, 2017 7:33 am
by Treeman
Hi,
It’s a while since I started this thread, but I eventually got to the bottom of the problem. It was a faulty fuel pump that continually flooded the engine. However, after speaking to various dealers I was told that the fuel pumps where all faulty on the model and when they first sold them they came with a spare!
I bought a new fuel pump, had it fitted and the problem disappeared and it started well….., for a week, then went back to poor starting and flooding! Did anyone have the same problem and find a resolution, like finding an alternative fuel pump that worked!?
Thanks,
Treeman
Posted: Thu May 11, 2017 11:17 am
by Treeman
OK, still haven’t solved this! Had a bit of lateral thinking and does anyone know if I could remove the fuel pump from the system, replacing it with a gravity feed system with a manual on/off tap with no effect on running (bit hopefully good starting!)?
Thanks!
