Stalls in first
Posted: Thu May 28, 2009 10:02 am
by oneday
Fitted Cam Lam 5 plate clutch yesterday, all seemed well for a bit. Then kicked over bike seemed fine in neutral, put it into first and it stalled. Kept trying with same result. Only way I could get the bike running was to rev the nuts off of it and it would wheelie but go. What have I done?
Re: Stalls in first
Posted: Thu May 28, 2009 11:50 am
by Dazza
Does it jump when you let the clutch out then stall?
If so did you soak the plates ?
Re: Stalls in first
Posted: Fri May 29, 2009 9:20 am
by oneday
Guess it may be that i didnt soak the plates for the recommended 24 hours then! As they have been in for a while now i will try tonight and see.
