Page 1 of 2
ts1 with diablo tank, mikuni on a series1. filter options
Posted: Wed May 27, 2009 11:19 pm
by cezeta
im using a diablo tank on my series1 ts1. i want to use a filter on the carb, any ideas
Re: ts1 with diablo tank, mikuni on a series1. filter options
Posted: Thu May 28, 2009 10:04 pm
by cezeta
that will be a no then
Posted: Thu May 28, 2009 10:05 pm
by Ian Hepworth
How much space have you got?
Posted: Thu May 28, 2009 10:09 pm
by Juan
Maybe PM Al to see if he's got an idea?
Posted: Thu May 28, 2009 10:17 pm
by J1MS
Panels are made to be cut... :baddevil:
Posted: Thu May 28, 2009 10:19 pm
by davidblythe
S3 No chance
S2 okay run the remote hose horizontal under the tank
my GP with cut toolbox
Posted: Thu May 28, 2009 10:28 pm
by sean brady scooters
just how does any fresh/cool air find its way into that..................?
Posted: Thu May 28, 2009 10:38 pm
by davidblythe
its a rolling test bed, so as one problem is solved another one develops
i enjoy the process, it keeps me amused
Posted: Thu May 28, 2009 10:48 pm
hope you can improve on the" rolling" stage dave ,and get it "rocking"............
Posted: Thu May 28, 2009 11:18 pm
by RBG
Make your own I did buy the foam & some glue.
Twinair motocrosser filter blanked off with foam & a hole cut in for carb
My RB22/mikuni 35mm tmx runs well with it on a GP.
Now fitted with a Diablo tank.
The panel does push the filter closer to the carb mouth but the filter still has a large internal area.
