connecting a battery charger to a loom to test eletrics
Posted: Wed Jun 18, 2014 10:21 pm
by gaz_powell
Can someone be kind enough to remind me how to connect a battery charger to a loom as a temp supply to test lights etc.
From memory you remove the brown from the regular and connect positive then put negative to frame/earth
Gaz
Re: connecting a battery charger to a loom to test eletrics
Posted: Wed Jun 18, 2014 11:22 pm
by Pepot
I guess that if you want to test everything you must conect the positive to brown,pink and purple from the loom and negative to the frame.
Posted: Sun Jun 22, 2014 5:27 pm
by JETEX
Depends on your wiring set up, but for say a straightforward AC electronic system, your post would be correct Gaz ( although I use an old car battery ).
Posted: Sun Jun 22, 2014 6:11 pm
by essexgp
I use a battery charger myself as they usually have short circuit protection built in and will shut down rather than with a car battery possibly melting the loom if there is a low resistance problem :shock: :shock: :shock: (batterys are normally about 45amps)
Posted: Sun Jun 29, 2014 5:01 pm
by nellyboyo
I use a small 12v power supply with over current protection
Posted: Sun Jun 29, 2014 5:50 pm
by ducksta
and testing a vespa px black to? red to?
