sip speedo for px - no horn
Posted: Wed Jun 18, 2014 7:22 am
by MCH
A bit of a electricery problem, iv fitted a sip digi speedo to my px but now my horn won't work properly, the digi speedo seems to be eating all the power, like I get a bit of a horn but it sounds like it's being strangled , iv checked the output and it seems to be about 5 or 6 volts coming to the horn, if I turn an indicator on while it's running, I won't get any sound at all, with the engine off I get no horn even though I still have a battery connected, but I have disconnected the elecy start at the relay end. Any ideas?
someone told me they had heard of this before but couldn't remember where they saw a thread or on which forum to sort the problem
Re: sip speedo for px - no horn
Posted: Wed Jun 18, 2014 8:12 am
by firekdp
Have you checked the fuse?
And which wires did you disconnect at the relay?
Posted: Wed Jun 18, 2014 8:19 am
by joeythescooterboy
Flat battery?
Posted: Wed Jun 18, 2014 11:58 am
by MCH
the brown fuse is intact, no problems with it, I will double check the connections though and try another just in case
battery is brand new, I tried another battery and still nothing, both are charged
I disconnected the black wire from the yellow relay which feeds to the electric start,
the horn worked fine before fitting the sip speedo with the above the same
Posted: Wed Jun 18, 2014 9:00 pm
by MCH
sorted it,
wires to fuse were the wrong way around
Posted: Wed Jun 18, 2014 9:23 pm
by firekdp
MCH wrote:sorted it,
:?: Bit strange as, if the fuse was intact, it wouldn't make a blind bit of difference where they went. As the fuse is just a link, all wires are connected together.
Even so, if it was working before, who changed them? :D
