RB20 big end bearing
Posted: Wed Jun 11, 2014 7:46 pm
Total novice when it comes to tuned engines! But here goes;
I'm running an RB20 with all the upgrades recommended by AF Rayspeed including running 4% mixture. On the way home from Tenby, the bike decided it didn't want to continue! Anyway, long story short, the big end has overheated and has given up. My local expert is removing it and after discussion with AF it is going back to them for an inspection as it has only done 400 miles. AF state in their literature that 4% mix is a must as any less can starve the crank of lubrication. I filled up in a Texaco station and use Silkolene oil.
So, to the question; WHY? I can live with these things happening if I can understand why and can do something to stop it happening again. I don't believe for a minute that AF will say that it is a manufacturing fault. Consequently, I will have to shell out another couple of hundred pounds and potentially wait for it to happen again!
Any thoughts gratefully received.
Cheers, Leighton
Cheers, Leighton
