Gp 150 piston/cylinder clearance.
Posted: Tue Jun 10, 2014 10:27 pm
by mikeveslam
I have got a New s.i.l gp 150 cylinder with a Mahle piston from scooter restorations. For my li 125
(Was Going to put a casa 186 on when funds permit) the piston/cylinder clearance is 0.0020" checked with feeler gauges.
Ring gap is 0.25 mm( can't measure piston. Clearance in mm as my gauges don't go that small)
Are these gaps ok for trouble free running in??
Cheers mike
Re: Gp 150 piston/cylinder clearance.
Posted: Thu Jun 12, 2014 9:17 pm
by handofdave
i like my piston clearances in air cooled machines a touch larger than .002 but run it in steady and it should be fine
dave
Posted: Thu Jun 12, 2014 11:10 pm
by mikeveslam
That's all I needed to no. Cheers dave
Posted: Fri Jun 13, 2014 2:18 am
by Grumpy225
.002" is too small. I like to have everything set up to .0035" for cast iron (with correctly chamfered ports). Been doing it like that for about 20 years, no problems.
The big problem is the way you are measuring your clearance. You really need proper inside/outside micrometers and measure the parts in the correct places. Feeler gauges are great for measuring points gap and end plate float but no good for measuring piston/cylinder clearances.
Posted: Fri Jun 13, 2014 7:57 am
by handofdave
rapido race kits come in at .002"
Posted: Fri Jun 13, 2014 8:24 am
by YAMLAM
handofdave wrote:rapido race kits come in at .002"
Harry Barlow done my Rapido classic and put it to .004.
Posted: Fri Jun 13, 2014 10:31 pm
by Muppet
2.5 thou perfekt for 57mm pot
Posted: Sat Jun 14, 2014 7:59 am
by chris2470
If you half the piston diameter and use this a guide you wont be too far out. i,e:
225; 70mm /2 = 35mm so use 3.5 thou
200; 66mm /2 =33mm so use 3.3 thou
150; 57mm /2 = 28.5mm so use 0.28 thou
etc, etc.
Posted: Sat Jun 21, 2014 1:52 pm
by Special X
I'd go with
225 4 thou'
200 3.5 thou
186/175 3.2 thou
150 3 thou
To avoid seizure.
Posted: Sun Jun 22, 2014 9:17 am
by mikeveslam
Thanks for the above info lads, had it done to 3 thou & is now up and running again,
It's run in time
Cheers mike
