which gearbox and sprockets
tea5ive
Main scooter: cometa 140
here is the set up...so far
imola mk2 (standard)
v-force reed block
62/116 crank
varitronic ignition
dellorto vhsb 37mm (bigger is better)
rev-tour exhaust
rocho 6 plate clutch 46t
what are my options on gearbox/sprockets ? baring in mind I would need to use the 46t crown wheel. cheers simon
johnd
Main scooter: 1970 Dl125
What port timings does the 62 crank give you? Work from there I suppose. Rev-tour? Characteristics?
