Page 1 of 2
Which drive sprocket?
Posted: Mon Jun 09, 2014 12:49 pm
by lammer205
What drive sprocket is best on my scoot set up TS1 ,franspeed road, li150 box, and 46 crown wheel it was on af close ratio box but lost a tooth on the cluster so needs sorted soon, so what would you recommend 16/17/18/19? Thanxs Lammer205.
Re: Which drive sprocket?
Posted: Mon Jun 09, 2014 1:08 pm
by corrado
Your best bet is downloading Tony Cassidy's gearbox visualiser, it's brilliant, it lets you compared different set-ups.
viewtopic.php?f=7&t=28888
Posted: Mon Jun 09, 2014 1:44 pm
by lammer205
Me, being a novice it would still be a guess(lots of numbers to look at on that) but a professional opinion would be great!!
Posted: Mon Jun 09, 2014 2:51 pm
by stokky
OK, here's what I do.
Use the "Lambretta Overall Gearbox Visualiser" from Beedspeed website.
http://beedspeed.com/html-pages/Lambret ... oChart.htm
That gives you final drive ratio's for any given gearbox and sprocket combination
Then I also use a chart off CAM LAM website that gives all sprocket combinations, and correct chain length to go with it.
http://www.lambretta.co.uk/downloads/gearbox.html
Also remember if you get a pull down chain tensioner gives a bit more flexibility on chain length
Finally the larger the front sprocket the less wear on your clutch
Posted: Mon Jun 09, 2014 3:15 pm
by stokky
ok without all the charts etc.
My TS1 (bit tuned) I had at final drive 4.81 (pacemaker and 47-18 sprockets)
Good all round drive
Posted: Mon Jun 09, 2014 6:42 pm
by phil23fair
stokky wrote:ok without all the charts etc.
I've got the same setup and agree with Stokky
Posted: Mon Jun 09, 2014 7:12 pm
by lammer205
Thanks lads,
As i have said above i need to use a 46 crownwheel(long story but this is my only option at this time) so it will have to be 46/?? to get me going any thoughts? thanx Lammer205
Posted: Mon Jun 09, 2014 7:19 pm
by Muppet
exhaust?
Posted: Mon Jun 09, 2014 7:28 pm
by lammer205
Franspeed road mate.
Posted: Mon Jun 09, 2014 7:46 pm
by joespeed
lammer205 wrote:Thanks lads,
16 poss 17
