Page 1 of 2
64mm (185cc)pistons- any good or shite?
Posted: Sun Jun 08, 2014 7:43 pm
by scooterslag
Just scored myself a proper scooter restorations SR185 barrel and head which Harry Barlow has reworked, now I need a piston as there isn't one with the kit, now I don't want to change the rod and run a jap piston but all there is available are pistons from either eBay, Beedspeed, or AF which all seem to be the same non-brand indian pistons, are these any good? I've heard stories or crap rings and ring pegs coming loose
Re: 64mm (185cc)pistons- any good or shite?
Posted: Sun Jun 08, 2014 8:47 pm
by Doom Patrol
Pretty sure I've heard of someone using a Suzuki TS185 piston. I'll see if I can find out some details.
Posted: Sun Jun 08, 2014 10:13 pm
by johnd
Mugello piston will work, or an oversize SR?
Posted: Sun Jun 08, 2014 10:19 pm
by scooterslag
Don't know about the muggy piston but scooter restorations don't sell the 64mm wire ringed piston any more
Posted: Sun Jun 08, 2014 11:03 pm
by Yanker
Muggy 64mm piston for the initial bore (no oversizes)...Then will your cylinder go to 66mm?
Posted: Mon Jun 09, 2014 1:46 am
by scooterslag
[quote="Yanker"]Muggy 64mm piston for the initial bore (no oversizes)...Then will your cylinder go to 66mm?
That said[/quote
not too sure, it started off originally as a SR175 barrel then it was taken out to and tuned by Harry Barlow to 185. I've considered the 66mm option as it would be cheaper to source a decent 200cc piston rather than forking out for a Muggy/MB etc piston. Don't want to go mental with it- just a 20/22mm carb and a slightly modified standard pipe, basically a stock standard 200cc lammy spec
Posted: Mon Jun 09, 2014 9:05 am
by CPH Lambretta
Deanspeed from the US do a 186 piston, I think Corrado said he had some in stock a couple of weeks ago.
If you use the TS 185 piston you will have to top and tail the barrel or use a longer con rod.
Posted: Mon Jun 09, 2014 10:33 am
by speedy
If Harry has done the work, hasn't he got any suggestion as to what to use?
Posted: Mon Jun 09, 2014 11:37 am
by scooterslag
speedy wrote:If Harry has done the work, hasn't he got any suggestion as to what to use?
will try and contact him at some point- I was just seeing what's out there
Posted: Mon Jun 09, 2014 12:32 pm
by johnd
+1 on the deanspeed piston. 64mm and will slot straight in (check the clearance of course).
should be cheaper than a mugello piston.
