PHBH 26 Slides
Posted: Sat Jun 07, 2014 6:53 pm
Guys
what is the difference between slides on these carbs. Am I right in thinking a 35 has less of a scalloped cut out on the leading edge compared with a 40 or 45.
looking at the round slide they must all be the same diameter and height.
I have a 35 slide in the carb I bought of a fantic 250 2 stroke. It runs pretty good up to now. but with the tickover screw all the way in it is just a bit too slow. and cuts out. Should I be looking at increasing the pilot jet its a 55 at the moment and the only other one I have is a 53
I am doing choke tests without the main jet in at the moment.
Happy to take the dremel to the slide, to be honest already have and its a lot better than it was but dont want to go too far if I should be looking at a bigger pilot
