piston
sjc
my mate has just holed a piston in his indian cast 200 barrel,,,wot are the piston alternatives quality wise to use as a replacement,,,cheers steve ;) ;)
The standard Indian Mahle piston is actually an excellent piston and better than many of the Italian option... and a lot cheaper too! This is one of the items that the Indians improved on and should not be discounted.
As piston holing is not related to piston choice your mate must still look to rectify the issues that caused it to hole. Ignition timing, fuel burn temperature (fuel quality), jetting and fuel starvation are the most likely causes and should be looked at.
Good luck with it.
bristolmod
+1 Mahle from Scooter Restorations- about £35.00 and very good quality.
Chris
Scootering since 1968.
lockman69
+2 on the injun 3 ring 66mm piston
goldeneye
nowt wrong with a Mahle in a stage 4 (the rings were made to tight tolerances as well), leave the bottom ring off though, it does nowt , and the groove will hold extra oil in the bore for a bit of lubrication. if your mate has holed a piston, its under jetted, over timed, air leak, or s**t fuel. don't blame a piston , it wont hole itself ;)
sjc
thanks for the replys,, not blaming his piston, just wondered if there was a better option,,if you recommend the mahle thats good enough,,thats wots in it now,, is there any compression issues with standard of the shelf indian cylinder heads?? thanks for the input..
handofdave
Main scooter: li ts1
2 ring asso and remachined cylinder head
JETEX
I holed a piston at the Euro in Ireland due to under jetting of my 22mil Jetex carb on a standard Indian GP 200 engine. I replaced it with an Indian piston, up jetted to a 125 main, re-set the timing and it took me to the Euro in Belgium with no problems, and up into Holland after that. It's still going strong now.
