Page 1 of 2
Suitable bearing drift
Posted: Mon Jun 02, 2014 6:49 pm
by djh66
Anyone got any ideas, what I could use as a main bearing drift, needs to be about 62mm diameter?
Re: Suitable bearing drift
Posted: Mon Jun 02, 2014 6:51 pm
by Andy Pickering
Bloody big socket ? Although drift would be more suitable
Posted: Mon Jun 02, 2014 7:21 pm
by Muppet
Nylon
Posted: Mon Jun 02, 2014 8:05 pm
by gaz_powell
better to use a puller than a drift - some times the bearing is a tight fit even after heating the casing/freezing the bearing (mind sometimes they fall in)
couple of big washers/round plates and some threaded bar
Posted: Mon Jun 02, 2014 9:38 pm
by djh66
Muppet wrote:Nylon
My wifes'???
Posted: Mon Jun 02, 2014 11:26 pm
by Knowledge
This is not the full answer, but I noticed that the outer bearing race from the steering column is the correct diameter to rest on the outer race of the main drive-side bearing.
Now, what to do with this observation....... I thought about using it as the basis of a drift or a puller.
Posted: Tue Jun 03, 2014 12:11 pm
by a.lo.v2
175 piston ? :lol:
Posted: Tue Jun 03, 2014 10:46 pm
by Lamaddict
Barrie B shows you how to make one from an old bearing in Scootering, can't remember the issue number. I made one and it works well.
Posted: Thu Jun 05, 2014 2:59 am
by corrado
I got a bearing extractor / fitting tool from Rich Presley a few years ago, it was expensive, over £50, but it's been a great tool and I must have used it over 50 times so paid for itself a few times over.
Posted: Thu Jun 05, 2014 8:06 pm
by djh66
I bought a large bolt and nut, with a few large 62mm washers to use to pull the bearing in, trouble was I was scared of damaging the casing and needed 2 pairs of hands as the engine was still in the scooter. After heating the casing a freezing the bearing I ended up taping it in around the outside of the bearing.
