Sip tubeless tyre pressures?
Posted: Sun Jun 01, 2014 5:24 am
I saw loads of posts before on the lcgb site, any good advice on what to run a front and rear tyre pressure at. I have sip stainless rims fitted with conti tyres. Also have a spare scootrs tubeless rim fitted with a schwalbe weatherman (changed to sips because rims seem a million times better and worried about schwalbe horror stories), if I every need to use the scootrs spare does anyone know if it will fit the s stud and nut combination? Or would I need to use different nuts, install the old studs in the hub?
Sent from basel using my pornpad
