according to this diagram
http://forums.fourtitude.com/showthread ... 0c9a927b0f
then the 5899-1 has a leaned out high RPM
the 5899-4 has a leaned out low RPM
and the 5899-2 is the same dia holes in all 3 locations
so i guess this would make it the richest atomiser
this assumes though that the internal diameter of all 3 atomisers is the same
which might not be the case
i cant tell as ive drilled all mine out to 2.00mm to try and get through the
60mph "restricted" limit on my almost run in SIL stage 4 iron barrel with a
clubman and bored out jetex
pulls great all the way through to 2/3rds throttle then doesnt want to rev on any more
im not pushing it as im only giving it the odd quick blast and ive only 100 more miles
to get to the 1000 and fully run in
