Welding on a scooter
Posted: Wed May 28, 2014 8:56 pm
by Tractorman
Do I need to disconnect anything before doing any arc welding on a scooter. There is no battery on it and the fuel tank is off.
Re: Welding on a scooter
Posted: Wed May 28, 2014 9:23 pm
by roli-olo
No,but if you are using stick or mig the spatter will get everywhere.Didn,t see you at ruskington tonight btw.
Posted: Wed May 28, 2014 11:24 pm
by thebassmasta
yes ! disconnect your earths from your stator plate, or if you have a battery dissconect
Posted: Thu May 29, 2014 9:13 am
by Tractorman
roli-olo wrote:No,but if you are using stick or mig the spatter will get everywhere.Didn,t see you at ruskington tonight btw.
It was wet and it was a long way. I just have to tack a tail pipe bracket on then remove the exhaust and weld it up.
Posted: Thu May 29, 2014 9:15 am
by Tractorman
thebassmasta wrote:yes ! disconnect your earths from your stator plate, or if you have a battery dissconect
Thanks for that, thebassmasta.
Posted: Fri May 30, 2014 10:30 pm
by thebassmasta
no probs pal
Posted: Sun Jun 01, 2014 10:40 pm
by Trojan
Thats right ,remove the earth wires from the casing to frame seeing as the rear shocker and engine mounts are separating the contact with the bushes, if I can advise, we normally weld at least three to four small tacks on a job save the pipe pulling over as its being welded, hope this helps.........
Posted: Sat Jun 07, 2014 7:48 am
by Tractorman
Job done with the help of your good advise and everything still works, thanks
