Page 1 of 2
AIR HOSE TO FIT OVER PHBH BELLMOUTH
Posted: Wed May 28, 2014 12:52 pm
by Agent Buchwald
Hello, I believe these do exist somewhere - I'm after a right angle air hose that fits over the plastic bellmouths on Dellorto PHBH carbs, anyone know who sells them? Thanks in advance.
Re: AIR HOSE TO FIT OVER PHBH BELLMOUTH
Posted: Wed May 28, 2014 12:54 pm
by Andy Pickering
Not sure tbh but you can unscrew it and get plenty that do fit
Posted: Wed May 28, 2014 1:04 pm
by tonydevon
just unscrew it and the normal lambretta one fits, I have a scootrs one on my phbh28
Posted: Wed May 28, 2014 1:51 pm
by Agent Buchwald
Thanks for the replies - I've got the standard one I was just hoping to experiment with airboxes and use a bigger hose that is not quite so restrictive. I'm sure I've seen some but can't remember where, cheers, Jon
Posted: Wed May 28, 2014 1:58 pm
by cgt75b
Agent Buchwald wrote:Hello, I believe these do exist somewhere - I'm after a right angle air hose that fits over the plastic bellmouths on Dellorto PHBH carbs, anyone know who sells them? Thanks in advance.
Lth do them. I am sure Harry Barlow had some :D
Posted: Wed May 28, 2014 2:01 pm
by Agent Buchwald
Strangely enough it came up during a conversation with Harry Barlow but i didn't ask if he had any, thanks for that.
Posted: Wed May 28, 2014 2:24 pm
by corrado
I've got the breath sweet rubber on it's own that fits the 60mm opening of the PHBH with the screw on bellmouth. Not sure how you'd make it fit the airbox though.
Posted: Wed May 28, 2014 2:47 pm
by Agent Buchwald
corrado wrote: Not sure how you'd make it fit the airbox though.
Some hideously welded collection of unsuitable pipes and butchered boxes I'd imagine - persevere up to point of contemplating suicide and then find that going open mouth solves all problems of my own making.
Thanks for getting back and pm sent.
Posted: Wed May 28, 2014 3:15 pm
by corrado
I think I've previously bought every plastic tubing option that B&Q sell trying to mate up Ramair filters to breath sweet hoses, though thankfully I've now got decent supplies of the proper breath sweet filters. I reckon that one or two strips of old innertube might bridge the gap or a mix and match with double sided tape, the thick stuff for mounting number plates.
Posted: Wed May 28, 2014 3:42 pm
by tonydevon
Ive used the elbow with 42mm bore at carb end, clamped down onto the threads, and a ramair filter fitted to the OD at the other end, all fab and groovy, although Im now going to try a ram air direct onto the carb as Im not sure if its flowing enough air as it is
