Wiring for 1979 Vespa PXMk1 headset ignition/front headlight
Posted: Tue May 27, 2014 6:32 pm
by wink
Hi All,
I'm just finishing off the restoration of the above and I now need to wire up the headset (with ignition key in the top) to the main loom. I have the three section of wires coming from the switches down to the lower loom and the horn, but can anyone tell me what the correct sequence is for the wiring up into the headset, along with the additional wiring segment (yellow & black wires).
Also can someone advise of the correct routing for the cables and loom coming from the headset to the main frame. ie gear, clutch and throttle cables and their correct placing against the wiring.
Thanks in advance Chris
