gear cluster
Posted: Tue May 20, 2014 9:49 pm
I've stripped down my TS1 SIL engine casing and I've got a couple of questions before refitting...
I've found the gear cluster bush raised around 1mm with its underneath shim slightly loose.
Does it only require to be hammered back in place or to be change?
No markings inside the bush but the bearing surface at the bottom gear cluster shows pittings the same on the cluster needle cage.
It has an AF Close Ratio Gearbox and I havent left the cluster shim out but THE book says to do sometimes....when?
Also, the engine casing area around the cluster bush is not flat like italian casings but scored like all the three SIL engine casings I've bought from new.
Is it a problem to leave it like it is? or it can cause problems for the gear cluster spins correctly?
thank you very much!
