Page 1 of 2
Plug oiling in traffic
Posted: Mon May 19, 2014 8:31 am
by vRSG60
More woes, ride to Blackpool yesterday but when stuck in traffic the plug is getting sooty/oily. It's fine at high revs. If it stalls it's a bugger to get going, I whip the plug out and change it with the old one (clean).
I had a Champion N2C and changed to a NGK B7ES (closest the motor factors had).
Will trying to lean off the with the idle screw make much difference? I had a 48 idle jet and bought a 45 jet. I can't for the life of me remember if I replaced the idle when I replaced the 128 main jet with a 123.
I run Comma semi synthetic oil at 4%
Re: Plug oiling in traffic
Posted: Mon May 19, 2014 2:23 pm
by DigDug
Just get rid of the sidecar if you're getting stuck in traffic. :?
Posted: Mon May 19, 2014 3:29 pm
by coaster
What top end is on it? Do you run with a filter?
Posted: Mon May 19, 2014 3:32 pm
by vRSG60
Standard Indian GP200 with a filter.
Posted: Mon May 19, 2014 5:39 pm
by coaster
Have you tried drilling a 1mm hole in the bottom of the air filter elbow? That should allow the accumulated spit back fuel to drip through.
Posted: Mon May 19, 2014 7:01 pm
by jonnyjarvis
isnt 4% too much for a std 200 ?
Posted: Mon May 19, 2014 8:08 pm
by camel
jonnyjarvis wrote:isnt 4% too much for a std 200 ?
thats what i thought...dont we all run 3%?
Posted: Mon May 19, 2014 9:37 pm
by vRSG60
I'll give 3% a go. Ray at Rayspeed told me to use 4%
Posted: Mon May 19, 2014 10:04 pm
by mick1
Timing may be too far retarded ?? Any idea what it's set at ?
Posted: Mon May 19, 2014 10:10 pm
by vRSG60
No idea it's been fine up to now . Runs great batting along at 50 - 55 mph
Out on the floor.
K.T.F.
