Has anyone managed to fit an RS disk with anti drive to a jet with fat dampers? There are no instructions and I'm not sure it can be done. Maybe you need slimmer dampers not sure.
Had more than a few problems yesterday with this kit and had to through the towel in and revert to the old brake after many hours. We were not able to get any hydraulic pressure, tried two brake hoses gave up after running out of light and missed the cup final.
Before trying to fit this again, I want to check it can fit and two it will work
RS anti dive disk
serveta200
- Main scooter: Serveta 200 series 80
I have one on a series 80 lince with a set of spax mini sport dampers so it can be done. I'll take a few pics and post them tomorrow
- coaster
Go to the Chemists and buy a large Hypo Syringe (be prepared for some bewildermentRick wrote:.....We were not able to get any hydraulic pressure, tried two brake hoses gave up after running out of light and missed the cup final.
Rick
- Main scooter: Jet200
Would be great to see some pics...serveta200 wrote:I have one on a series 80 lince with a set of spax mini sport dampers so it can be done. I'll take a few pics and post them tomorrow
- corrado
- Dealer
- Main scooter: Lambretta GP
You can get that problem if you use some aftermarket hoses [some have thinner heads] with the supplied banjo bolts. That shouldn't stop you from bleeding it though, just that it'll leak.wack 63 wrote:If using the supplied banjo bolts they bottom out before crushing the washers so either modify them, fit fatter washers or change to better ones .
I stopped supplying them with the supplied hose and banjo bolts and now only use Venhill ones. I couldn't trust that the banjo bolts flowed properly and ended up filing a grove across the flow hole on both sides and drilling out the inner as some weren't drilled cleanly. No such issues with Venhill.
serveta200
Rick I have some pics for you but cant seem to post them for some reason. PM me with your email and I'll send them on
