S2 with185 kit
Posted: Sat May 17, 2014 8:56 pm
by Livi- Graeme
Going to fit a 185 kit on my s2 li125. My question is would I get away with fitting a ma19bs5 carb because I would like to keep the scooter standard looking. If so any recommendations on carb settings. Thanks Graeme
Re: S2 with185 kit
Posted: Sun May 18, 2014 9:37 pm
by Rotor
I have this set up, but with a 22mm bored/reamed to a 24mm , this can be used with a modified air box. is it top end your looking for ? Because without playing with your ratios you'll not see much more than 45-50 Revving it to death until your crank has enough. P.
Re: S2 with185 kit
Posted: Sun May 18, 2014 10:09 pm
by Livi- Graeme
Yes already changed my front sprocket to a 19 and going to proberbly fit a 28mm delortto to it. Have a s2 already with a similar set up. Just need a bit more speed to make using it a bit more enjoyable. Thanks for your reply graeme
Re: S2 with185 kit
Posted: Sun May 18, 2014 10:33 pm
by Doom Patrol
I wouldn't keep the carb. It would only limit it.
