How do you check for big end wear?
Posted: Wed May 14, 2014 11:20 pm
Hi all,
I've got the barrel off my SIL GP200 to fit new rings and a new little end while I'm at it, but would like to know the proper way to check for wear on the big end and what the wear limits are.
I presume I use a feeler gauge for this but got no specs to use. The con rod does move freely from side to side a little but does not seem to have any up down play but its very hard to check for up/down and I'd guess it would have to be pretty well knackered to have obvios up/down play.
Is there a trick/rule of thumb type thing by how much you can get the con rod to move that is a good indication if its good or bad??
I did have a light tapping/ticking noise coming from what seemed to be the cyl head area hence stripping it down to fit a new little end and rings at the same time, but the rings are worn in the groves so that could have been the ticking, or it could have been the little end but hard to check up/down movement on that.
If the big end is gone that'll be me knackered for a while, not an easy job I guess!
Best regards,
Eric.
Best regards,
Eric.
