any ideas?
Posted: Mon May 12, 2014 2:24 pm
by gp200ts1
had a problem with the Avanti last weekend. started belching white smoke and wouldn't run without the choke. assumed it was the drive side seal so I've replaced the seal and put a new bearing in with the extra seal fitted. cleaned the carb and drained the tank and put fresh fuel in. bloody thing is still smoking like it has an eighty a day habit and still wont run without the choke. steel drive side bearing plate and quality seals from MRB. skf bearing, European made. no marks on the crank seal face so at the moment I'm stuck. any one got any advice?
Re: any ideas?
Posted: Mon May 12, 2014 5:42 pm
by wack 63
Get it pressure tested then you will know if it' s a leak
Re: any ideas?
Posted: Mon May 12, 2014 5:49 pm
by dave wheeler
pipe and/or crankcase may still be contaminated with gear oil
Re: any ideas?
Posted: Mon May 12, 2014 6:50 pm
by tea5ive
Have you put diesel in by mistake?
Re: any ideas?
Posted: Mon May 12, 2014 9:52 pm
by OAP
None of the above, been sorted! no doubt Paul will tell you. Choke was a bum steer though!
Re: any ideas?
Posted: Tue May 13, 2014 3:57 pm
by gp200ts1
thanks to Ron who pointed me in the right direction. turns out it was the float. ethanol in the petrol had worked its magic on the float and it was leaking. all sorted now
