Major Gremlin
Posted: Sun May 11, 2014 8:56 pm
I've come a cross most Lambretta problems in my years of scootering but this one has go me baffled. I have recently convert my bike to full DC on the lighting circuit using the following. New BGM 120w DC stator, New BGM flywheel, Wassal regulator, 12v 9amp battery, Beedspeed TV series 1 style ignition switch. On the ignition side a new CDi unit & HT lead. When all was connected I had great lights, horn and power to run a rev counted and Sat Nav. All sounds good. But this is the Gremlin I am baffled with. After first running the bike all seemed ok, engine fine but a bit groggy at bottom end, lights ect fine. I then took it for a duno run. This was also to sort out the groggy bottom end. After five runs and a nice curve on the graph things were looking good. Until run six when the power just died at mid range. Tried again but it wouldn't run high revs.
I rode it home and started to investigate the problem. I first tied a new CDi but it was still erratic at bottom end and reluctant to rev. It was only when I had disconnected the battery while getting to the CDi that I discovered that with the battery disconnected all ran fine. Yes,, with the battery disconnected the engine runs smooth and revs fine, but connect the battery and it starts to splutter and difficult to rev. So I tried a different flywheel. Did the same. Disconnected the ignition switch but still did the same. I have removed the stator and tested it, green 505 ohms, red 105 ohms, white to earth 0. Check condition of the stator wires all look fine and undamaged.
So why when my battery is connected dose the engine splutter but runs fine when disconnected. If anyone one has any suggestions please please let me know as this is baffling me.
Regards
Tombretta
Regards
Tombretta
