Wiring daytime running light
Posted: Sat May 10, 2014 8:24 pm
I have wired a daytime running light on a mates PX, fused feed from battery to relay, and found a wire in the horncast that had a insulated female spade connector on, not connected to anything that is live when bike is running, ideal, I thought for my switched feed. The problem I have is that the light strobes quickly, instead of being constant!
What was the feed for that I used, as It was not connected to anything?
and, is it this that is causing the strobing?
I have tested the light from my battery charger and its' fine, so its not the light that's at fault!
